Home > Technical > Are there sports exhaust options available for a TDV8?
Mr. Green
nearly as long as this one
 RRS gone
Post #353581 Mon Aug 13 2012 11:19am
Rolling with laughter ON THE WAY: BMW F21 M140i
Post #353586 Mon Aug 13 2012 11:36am
DMike
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Ady 555 wrote:
So is that a loophole there then? Because if you read the manual, it states where a cat has been previously fitted ie by the manufacturer and isn't fitted to the vehicle at the time of the mot test then its a fail Shocked As there is no emmissions test carried out for a diesel only a smoke test, one would think that without a cat it would be a fail Confused I can't see anywhere where it says except diesel powered vehicles.
It's not in the current manual, as far as I know, but when the new rules were published, they stated only spark ignition engines need to have a cat fitted as part of a test. No mention of diesel engines at all
That said, our previous MOT station did fail a few (diesel) cars for not having a cat, until this fact was pointed out to them. Not had an issue since, even when moving to a different testing station Thumbs Up
Post #353980 Fri Aug 17 2012 6:07am
