Home > General > A couple of strange occurrences......
m3grant
Hi, I have a 56 plate 2.7 tdv6 HSE that I love to bits. However over the last couple of weeks or so I've noticed a couple of strange things happening ....
The first was when I was washing the tailgate I noticed some strange scratches that line up perfectly with a couple of metal bits on the rear wiper if it had attempted to rotate the wrong way during operation. I can't imagine how this could happen but it's odd how the scratches line up perfectly.
Next is the touch screen, the other day it was stuck on the welcome screen. Well not exactly stuck as the hard buttons worked fine but not the touch screen. After 5 mins or so of driving it worked fine. The same thing happened again this morning but after a minute of driving I wiped the screen with my hand and it started working.....am thinking maybe static build up or something?
Yesterday the sat nav lost it's position for about 10 mins. I was driving along and three little arrow was hurtling through fields etc and suddenly came good. We live in the country side so it can't be buildings obscuring the signal or anything.
The final thing is the other day the yellow engine symbol lit up just after I'd pulled away from being parked. It stayed on until I switched the engine off and it said Park Brake Fault?
Sorry for the massive message, I thought I'd ask on here first before I went to my local dealer.....who incidentally is a robbers dog Smile
Thanks in advance. Grant.
Post #351005 Wed Jul 18 2012 7:39am
simple1
Not sure about all if these but mine did something similar with sat nav loosing map. Took the disc out of player under passenger seat and cleaned thick layer of dust off it. Worked fine after that. Not sure what the rest is. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #351016 Wed Jul 18 2012 9:30am
neildurno
Scotland 2007 Range Rover Sport TDV8 HSE Java Black
Maybe it was a new road you were driving on and the sat-nav thinks you are in a field? Maybe need an updated disc! Range rover sport 3.6tdv8
Mitsubishi lancer evo 9 fq 360
Landy defender 90 tdi
Post #351028 Wed Jul 18 2012 11:10am
MAW
Quirky electrical faults can sometimes be indicator of battery on way out .....
Post #351059 Wed Jul 18 2012 4:36pm
m3grant
Thanks for the replies. It was a road I travel on a lot and it does exist on the disc so I'm gonna check the disc for dirt and have the battery checked out as advised. Will keep you posted, thanks again.
Post #351064 Wed Jul 18 2012 5:23pm
