mcgovern01
Intermittent cruise control | |
I am having a problem with the cruise control (or maybe just the buttons)
RRS s/c with adaptive cruise.
Cruise does not work, but sometimes after punching the crap out of various buttons I can get the cruise 'set' (+) to work. It will accelerate if I press the + button, and the resume button works, but '-', 'cancel cruise' and both of the cruise distance controls are innoperable. Nor can I adjust the forward alert distance if I have that turned on.
I have read on this forum about possible clock spring/wiring loom/silicone gel in ECU faults, but none of them seem to fit my problem, in that I can get it to partially work? Any ideas?
I have tried to remove the left hand switch panel to see if the contacts need cleaning, by removing the 2 screws at the back of the steering wheel, but I couldn't get it off. (didn't want to force anything or risk the airbag going off!) any guidance here will be much appreciated!
Also can someone tell me where the ECU with the silicone gel is located so I can check this?
Any other suggestions gratefully received! Otherwise a potentially costly 'diagnostic' at the stealer....
Thanks
Phil Range Rover Sport Supercharged
55 plate
Bonatti Grey
Ivory Leather
Side steps
Gone but not forgotten...
Range Rover L322 Vogue Black
Range Rover P38 4.0 Blue
Range Rover Classic Black
Land Rover 130 Crew Cab V8
Plus many other non landrover, including BMW and Audi, neither of which satisfy as much as a range rover - when it's working properly!
Tue Jul 17 2012 11:31pm |
