![]() | Home > General > Oil Or diesel leak |
rogerpop Member Since: 14 Jul 2012 Location: blackpool, Lancashire Posts: 14 ![]() ![]() |
Update.........Its a diesel leak, Had to remove battery and box, remove cover over injectors and it is leaking from small plastic fitting (at side of injecter) which i think returns fuel. New rubber seal ordered at a cost of 78p. Should get new seal tomorrow. roger |
Job done. A bit fiddly "O" ring only about 5mm outside dia. No more leaks. |
Nice one |
