Home > In Car Electronics > Alarm
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Alarm
Hi my alarm is crap, I mean theres no way its waking me up if some baloon head broke into her. Can it be highered or changed for summit descent?
Post #350242 Mon Jul 09 2012 10:00pm
I recognise the words as being English but the way they're put together makes little sense... Whistle 2012 SDV6 - it's missing a couple of cylinders
Post #350246 Tue Jul 10 2012 12:12am
looneyfitter
Really? Well. When the alarm goes off you can barely hear it. Whistle
Post #350255 Tue Jul 10 2012 6:59am
Ballsy
My alarm has a shockingly low sound. I think It's either swap the siren for an aftermarket one, wire it so the horn goes off aswell or fit a whole new aftermarket one.
Post #350269 Tue Jul 10 2012 9:35am
I thought (as per Disco 3) just by unplugging the alarm siren, the system automatically defaults to the horn...?
Edit:
yes this works on the D3 so I'm sure pre 2010 cars will have the same effect. RRS gone
Post #350275 Tue Jul 10 2012 10:20am
Bodsy
Site Sponsor
Yup, it does AWD Thumbs Up D3 and RRS the same. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #350277 Tue Jul 10 2012 10:30am
looneyfitter
Well that's good to know. Any know where the siren is? Doubt id be able to find it even if I set it off lol. On another note, if u pull the grill off, on the n/s there is a plastic cover. Behind this there is some sort of sensor. Any idea what it is? Mines hanging off
Post #350279 Tue Jul 10 2012 10:49am
easy... lock the car...break the passenger window.... open the bonnet and look to see where the noise is coming from Mr. Green Rolling with laughter RRS gone
Post #350280 Tue Jul 10 2012 10:53am
^^^ Rolling with laughter Always there with a 'helpful' answer awd...... ON THE WAY: BMW F21 M140i
Post #350281 Tue Jul 10 2012 10:56am
Bodsy
Site Sponsor
Sounder is near the brake pipes ABS unit. It is a black box with VOLVO written on it ISTR. Just disconnect (easier said that done) the connector and it will revert to your normal Horn. Bodsys Brake Bible
See it HERE
Post #350283 Tue Jul 10 2012 10:58am
Here's how to make the alarm system use the horns not the battery back up sounder.
This guide is for a RHD D3 for LHD everything is on the other side of the D3
1. open the bonnet and open the left hand box
2. Locate the alarm sounder, its just behind the ABS module and to the left of the brake servo (It has volvo on it)
3. On the alarm sounder there's a plug with three wires coming from it. You need to disconnect this It is fiddley and I used a small flat blade screwdriver to remove it. Then just tuck it away.
4. Once you have done the above the alarm system defaults to the horns.
To test lock the car give it 30 secs and then open the passengers door manually with the key this will set the alarm off. RRS gone
Post #350284 Tue Jul 10 2012 10:59am
All part of the service and free of charge Whistle
I did follow up with a more useful post I might add Mr. Green RRS gone
Post #350286 Tue Jul 10 2012 11:01am
Thud Shocked ......oh the shame.....I may have to try and sand that off mine Whistle Laughing ON THE WAY: BMW F21 M140i
Post #350287 Tue Jul 10 2012 11:03am
Why is it any worse than having a Ford engine under the bonnet? Whistle Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #350296 Tue Jul 10 2012 12:48pm
looneyfitter
muchas gracias i shall try this tomorrow Thumbs Up
Post #350366 Tue Jul 10 2012 10:10pm
