Home > Technical > How to switch off air con on MY12 RRS HSE?
The Red One
Hi everyone, I have had my MY12 Sport just over a week now and when I put the climate control on auto, the air con lights up and comes on, but if I press the air con button, it will not switch off? I have turned up the temperature settings and let it run for a while, but it won't switch off unless I switch auto off.
I had a D4 and recently an Evoque and was able to switch the aircon on and off when I wanted, can anybody help? Exclamation
Post #350126 Sun Jul 08 2012 8:27pm
Have an early night and try some bedtime reading of your manual. Thumbs Up Then in the morning you can tell us all if its possible Laughing But i don't think it is Crying or Very sad
Post #350128 Sun Jul 08 2012 8:34pm
The Red One
Have read the manual already and it says to just press it to switch it off, but it does not. I'll check with the dealer during the week if no one is able to advise on the forum.
Post #350129 Sun Jul 08 2012 8:46pm
Why do you want to turn it off? The point of climate control is that you set the temperature and it just maintains that temperature. 2012 SDV6 - it's missing a couple of cylinders
Post #350142 Sun Jul 08 2012 10:43pm
Meerkat
Hi,
I've noticed this too. On 'Auto' air con is alwaus on, you should be able to have auto without it, but I cannot see how. Air Con reduces MPG, so best to turn if off if not needed.
I will ask the man from LR that is coming to see me this week about my collection of problems!
Cheers,
Post #350144 Sun Jul 08 2012 11:09pm
oldcro
Scotland
Auto controls the selected temperature which needs heat from the engine and cold from the air con compressor, depending on outside temperature. No air con means no control so it must be on in auto mode. In cooler temperatures although heat is required the compressor chills the incoming air to condense the water out of it. This helps to reduce condensation forming on the inside to the windows.
Switching the air con compressor off for long periods invites problems like smells from bacteria forming and seals failing, so could be a false economy in the long run.
Has anyone actually tested the fuel consumption over a period of time with the air con off and on? Be interesting to know the differences. For the last twenty year or so all my vehicles have had climate control and each one has be set to my chosen temperature and not touched again, so I have no idea how much extra fuel was used.
Post #350145 Sun Jul 08 2012 11:41pm
rstebbings
This has been bugging me to as the Auto button on on my old 08 RRS never turned on the AC.
Post #350148 Mon Jul 09 2012 7:03am
If your worrying about mpg that the aircon uses the RRS might not be the best car to have Laughing
Post #350150 Mon Jul 09 2012 7:38am
rigsby
I looked on line and if you turn your air con off then you can expect about 45-50 mpg.
Thumbs Up MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #350152 Mon Jul 09 2012 8:07am
oldcro
Scotland
With AC off the auto button only controls the heat output and fans, so not air conditioning just heating control.
Having the AC off in hot weather means you may be roasting in the car, but allegedly get up to 45-50 mpg. Whistle Rolling with laughter
Post #350164 Mon Jul 09 2012 10:33am
whippetman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
The site I looked at quoted mpg for RRS of 60 plus with aircon off Whistle
Post #350165 Mon Jul 09 2012 10:33am
rigsby
And if you let it roll down the hills it goes up to nearly 70mpg. Honest.
Rolling with laughter MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #350168 Mon Jul 09 2012 11:13am
whippetman
On. more serious note on my vintage 2011 I can off the auto aircon by turning the knob anti-clocwise once or two clicks but then i find all steams up so back on it goes Thumbs Up
Post #350169 Mon Jul 09 2012 11:19am
rstebbings
I'm not bothered about the MPG (45-50 is a dream), if I were I would have a different selection of cars to what I have sitting on the drive currently, for me it is more to do with why it is on in the first place and why it wasn't on the old RRS
Post #350186 Mon Jul 09 2012 1:25pm
rigsby
The Red One, sorry mate I have an earlier car so can't really help. Seems strange to me though if you can't turn it off when you want to. Good old Land Rover. MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #350189 Mon Jul 09 2012 2:38pm
