Home > In Car Electronics > Rear Power Window
Tommyschuck
2007 Range Rover Sport TDV8 HSE Sumatra Black
Rear Power Window
I have a Range Rover Sport TDV8 2007.
Both rear windows donīt work. I found some threads about the ECU, which fails quite often. Only problem is, I canīt find the ECU under the fuse box in the passenger foot room. Can anybody help me with this newer range rover sport?? And no, I do not have the child lock activated!!! Twisted Evil
Post #350023 Sat Jul 07 2012 2:59pm
toeuk1
Did you get anywhere with this problem Tom? My n/s rear window won't work - fuse is ok.
Cheers.
Post #358964 Sun Oct 07 2012 11:55pm
Tommyschuck
No, they worked for one day, but now they are broken again.
Post #358977 Mon Oct 08 2012 9:00am
Culbert1
I think this is your problem.Either the window regulator and or the window motor must be changed. Take it to a store and have it diagnosed, but one if not both of those elements are your issue.
Prorack Roof Racks
Post #360713 Wed Oct 24 2012 12:31pm
