![]() | Home > Wheels & Tyres > Hankooks W rating |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
W is 168mph. For the non-SC RRS, the homologated speed rating is H (130mph) so W is obviously fine.
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
I have same tyres and they are great but be aware some dealers, ie York refused to carry out some warranty work because they are not the standard tyres that they come out of the factory, wonkers, and Land Rover did not want to know also wonk |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
Could insurance companies be a bit arsey if fitting non standard spec tyres even if the speed rating is crazy?
If they are the correct size/speed rating/load rating then the insurance company shouldn't be worried.
I can assure you I threatened them with all sorts but would not budge. |
In which case the op shouldn't switch to a W rated tyre as the cars come with Y rated.
2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
Just looked at the manual for the 2006 and it does state that the 19in tyre should be Y-rated which is 186mph. Which is amazing considering the car can only do 130mph.
Chomega Member Since: 09 Apr 2011 Location: Reading Posts: 20 ![]() ![]() ![]() |
Thanks for the responses guys.
