Home > In Car Electronics > reversing camera HIDS4U for RRS 2006
BWGRRS
United Kingdom 2006 Range Rover Sport Supercharged Rimini Red
Could anyone help in the fitting of the HID4U interface, and reversing camera, for my 2006 RRS.
Post #347437 Mon Jun 18 2012 3:39pm
flydive
this might help
http://rrsport.co.uk/forum/topic20219.html?highlight=reverse '08 RRS TDV8
Post #347441 Mon Jun 18 2012 4:16pm
pjb
Hi,
I have fitted one recently - at weekend - so can say how I installed mine.
It is fairly straight forward but you need to accept that you will have to run cables along the end of the glass tailgate as there is no access to the landrover wiring route as a bonded part.
Fitting camera is easy, just unscrew cover on tailgate handle - circa 6 torq headed screws - allows very easy access to light that you take out & replace with camera. - Its a tight fit to get camera in with the bulb holder
You then run cables from camera through a hole in plastic - I used the same place as the cables come through to power the number plate lights & tailgate handle.
Then need to run cables along edge of screen, through existing cable routes through body work - a real pain in the arse as you have to do it twicw once through the glass tailgate & then through the main tailgate.
By removing the rubber around the edge of the tailgate you can pull the cables out & take to bottom passenger side tailgate rear.
I used the reversing light to power camera - so only works on reverse then along with the actual camera singnal cable, I also ran a power from rear 12V+ aux & a cable from camera / reversing light to activate system when in reverse.
You have to very carefully lever off the trim that runs along side the rear passenger side to the b pillar to give a route to run the cable through.
Be sure to ensure you remove any metal clips especially on the threshold plates as they tend to stay in the bottom part & when you try to refix they just get pushed out & are a nightmare to then get out
Then simple connect the GVIF under the seat at the side of the sat nav & plug & play.
Just be aware it takes some time but is fairly easy plug & play the most difficult bit is removing trim & running cable routes.
Ian at hids is very helpful as is the disco 3 forum, which is where I got my first fitting experience as had a disco 3 & fitted one.
Might be someone on disco 3 forum local to you who has done the same thing who might be able to help Paul
L405 Loire Blue
Swift Conqueror 645
Abarth 500c
Post #347443 Mon Jun 18 2012 4:39pm
BWGRRS
Thankyou - very helpful
Post #347506 Tue Jun 19 2012 6:53am
abeachsoul
United Kingdom 2013 Range Rover Sport SDV6 HSE Orkney Grey
Elec diags
Post #349029 Thu Jun 28 2012 4:23pm
abeachsoul
Rev and Fwd cams...
Post #349030 Thu Jun 28 2012 4:30pm
BWGRRS
That sounds awesome Thumbs Up
I dont think I could attempt those mods. I would probably blow something up. Very Happy
Post #349121 Fri Jun 29 2012 7:14am
abeachsoul
Post #349474 Mon Jul 02 2012 1:12pm
rigsby
Hi abeachsoul, I am going to buy the reversing camera set up, when you say fwd cam, have you fitted a 2nd camera to the front? I don't want to do mine and then have to go back and re route another cable etc later on. If so what camera and how have you mounted it. Hides 4u only 20 mins from me so I may be able to get it all in one go, regards Rigsby MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #349498 Mon Jul 02 2012 3:03pm
abeachsoul
Post #349507 Mon Jul 02 2012 3:47pm
abeachsoul
Post #349510 Mon Jul 02 2012 3:59pm
rigsby
Pm sent MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #349530 Mon Jul 02 2012 5:53pm
abeachsoul
Post #349747 Wed Jul 04 2012 9:25am
