Home > Maintenance & Modifications > Replica Stormers and Tyre Size
Singletrack
Belgium 2006 Range Rover Sport TDV6 HSE Java Black
I'm confused...I'm trying to find Stormer wheels and tyres for the new RRS -I've see a number of replica options on ebay and vendor websites and can pretty much sort that out. I have two questions I would appreciate some feedback on.
1) Does anyone know who actually supplies LR the OE Stormer wheel?
2) I've seen packages with 275/40/20 tyres and others with 295/40/20 - the latter is larger than factory spec. Has anyone got this size mounted on either Stormers or some other wheel and have you encountered any problems with the larger tyre?
Of course...any other input is more than welcome! Bow down 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge
Post #36406 Wed May 31 2006 7:09am
Not sure who makes OE Stormers but someone will know!
I would avoid 295/40's as they are not the recommended size. a 40 profile of a 295 section tyre will be a higher sidewall than a 275/40.
With a 275/40, the overall size of wheel/tyre combo is the same as the 19" with a 255/45 (I think it is), therefore what you gain in wheel you reduce in sidewall. The rolling radius should still be the same. You will just get a firmer ride due to less pneumatic damping from a lower profile tyre.
I think I was just posessed for a minute then. That was surely not me typing that guff! Shocked Runner up - 2009 Best Avatar Award Sad
Post #36430 Wed May 31 2006 9:09am
Singletrack
ST...that is an impressive reply. Thank you Bow down Bow down Bow down 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge
Post #36540 Wed May 31 2006 1:10pm
You need help SuperT! 2005 Zambezi TDV6 - Gone but not forgotten
Post #36543 Wed May 31 2006 1:12pm
I need a priest, a cross and some holy water............
......is that pea soup on my computer? Runner up - 2009 Best Avatar Award Sad
Post #36546 Wed May 31 2006 1:22pm
