Home > Technical > Suspension dropped over night and squeaking front suspension
RRSTDV8DK
Denmark 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Hi
I have searched for a thread with the answer to this problem, but could not find anything?
I parked the car in driving height and when I came out the next morning the right back corner was dropped to access height, the three other corners were still in driving height.
When I started the car and drove off the car leveled it self. When parking after driving the car is level, but it will keep dropping right back corner when left over night.
Furthermore I have noticed squeaking from the front suspension when driving over speed bumps etc. The squeaking does not appear to be constant, i.e. this morning there were no squeaking driving over bumps that produced squeaking yesterday afternoon.
Thanks RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #344705 Fri May 25 2012 7:02am
muddywheels
Milk Float Man
There have been others with this issue - look here
http://www.rrsport.co.uk/forum/topic26732.html?highlight=
Hope you get sorted Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #344708 Fri May 25 2012 7:28am
ckevin
i have the exact same issue with my TDV8 , not solved yet.
Post #344783 Fri May 25 2012 6:28pm
RRSTDV8DK
Hi Muddywheels - did see that post, but in my case the suspension is all level when engine is on and when driving, no warning on dash or anything.
This morning I had the 4x4 screen on when I put in the key and it showed that right rear was lower and a little red bar was blinking - any idea what the red blinking bar means?
Turned the engine on and the suspension leveled it self. RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #345044 Tue May 29 2012 9:20am
muddywheels
Milk Float Man
Possibly a sensor fault Question
Hopefully someone on here can confirm better Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #345048 Tue May 29 2012 9:30am
jundrill
United Kingdom 2008 Range Rover Sport TDV8 HSE Siberian Silver
I had the exact same project. I had Brown Church change the offending's side height sensor (back near side) but it made no difference. I then took it back in and they re-set everything and its been fine since.
Do you ever get the red flashing light come up for any of the front wheels? (front near side for example?)
Since having the system re-set about 4 weeks ago I've not come out to find the back dipped in one corner.
Jon
Post #345684 Sun Jun 03 2012 9:06am
RRSTDV8DK
Hi Jon
I have noticed that when the car is left alone for more than a day, the front in the same side will also drop, and when left for approx 2 days it seams that the other corners will also drop some.
When turning the key without starting the engine, I can see, when the car is left for more than a day, that the red bars
will also blink for the front.
Do you think it is a simple thing as just resetting it?
Post #345893 Tue Jun 05 2012 12:18pm
jundrill
No, I take all what I said back. I went out to the car this morning and the back near side was down......
Damn it.
Post #345895 Tue Jun 05 2012 12:24pm
RRSTDV8DK
Ok - sorry to hear that
I have booked a inspection from the doctor for the car on monday. They suspect leaking airbag or in some of the plastic piping? Or maybe a valve ...
Let me hear how you get on with it RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #345922 Tue Jun 05 2012 4:53pm
jundrill
When I got mine inspected there were no air leaks and the error log was blank, really odd (although they changed the senor, but it made no difference, I still had the problem).
The only thing I have read which appears to be the answer is that on the same side of the car, the front wheel has the flashing red light on the diagnostics screen when the car is in the lower suspension mood (in the morning when the rear end is dipped low just before I pull off the drive).
I read somewhere that this may be causing the problem albeit that the red flashing line is showing up on the front near side and its the rear near side that’s dipping low over night.
Let me know what your inspection comes back with.....
Jon
Post #346219 Fri Jun 08 2012 11:36am
jundrill
I missed out the bit that by changing the front near side senor someone else with the same problem managed to resolve their problem.....
Post #346221 Fri Jun 08 2012 11:38am
RRSTDV8DK
Ok - the dealer just called and said it is a cross valve that needs to be changed - that will be £600 ... RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #347385 Mon Jun 18 2012 10:06am
Kensta
Oooof Java black 2006
Post #347387 Mon Jun 18 2012 10:20am
