Home > General > Is this normal?
pacmeoff
Is this normal?
Hi,
I have a MY12 RRS and noticed a few issues and was wondering if these are normal
1. when the weather is cool and for approx 5 minutes after starting the engine I appear to have a droning noise (maybe a blower). I thought it could be the heating/ac system but when I switch it off the noise is still there. The noise can be heard inside and out.
2. The touch screen seems really slow, sometimes the audio/video section can be greyed out for a minute or 2 after starting the engine and on occasions I have reveresed of the drive and started going forwards before the rear camera comes on.
3. Drivers seat get confused when exiting the car and pins me up against the steering wheel, then when I enter the car again I have to use the memory function to return the seat to normal position.
Thanks
Paul.
Post #342964 Wed May 09 2012 3:05am
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Re: Is this normal?
Number 3 definitely isn't normal.
Nik. 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #342967 Wed May 09 2012 6:11am
essexfarmer
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
I agree with Nik, no 3 not normal in fact it the seat should do the opposite and lower and the steering wheel should raise when the drivers door is opened.
I think you will find that the noise you hear on start up from cold is the fuel burning heater which carries on running for a while after you switch the engine off.
I have to agree that the touch screen is really slow and when reversing after starting the car the camera is just about useless unless you are prepared to wait for the system to boot up.
Shaun 12MY RRS Orkney Grey HSE Lux
12MY FF Santorini Black VSE
Post #342969 Wed May 09 2012 7:26am
1. As EF says, probably the Fuel Burning Heater.
2. Shouldn't be that long delay to be honest, but I've had similar every no and then.
3. Not normal. sounds like its got its nickers in a twist.
Maybe a full reset will snap it into shape. Search on here for details how to do that Smile ON THE WAY: BMW F21 M140i
Post #342975 Wed May 09 2012 8:14am
pacmeoff
All,
Thanks for your comments - I will try the reset and if that doesn't resolve issue I will book it in a the dealers.
Thanks
Paul.
Post #343025 Wed May 09 2012 1:03pm
