Home > In Car Electronics > HELP, SAT NAV screen swithed off wont switch on |
rabbutler Member Since: 11 Dec 2009 Location: Aberdeen Posts: 187 |
Just got into jmy car, started up aas usual, the sat nav screen was on but no sound coming from the radion, tried turning up the volume but still no sound, tried changing channels but was stuck on the current radion station, had my phone plugged in to th eipod connection so tried to play the music on my phone, but could select the adio device, could select the CD, also couldnt select the TV.
Fri Apr 20 2012 1:40pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Rab, The whole system is interlinked, so one issue can cause the whole thing to hang. Bluetooth phone linking can cause such issues. Best thing to try is switch car off lock it and leave for half an hour so that everything has shut down completely then try again. If you had your phone on you when it failed the 1st time try leaving it away from the car when you retry so it doesn't try to link.
Fri Apr 20 2012 1:53pm |
Hi endjin, yip did that and that seemed to clear it. Started the car up again and all was good.
Sat Apr 21 2012 9:43pm |
Ahhh the joys of owning a Range Rover Quirky B ers ain't they! But ... we still love emm! Glad you got it sorted 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Sat Apr 21 2012 10:51pm |
