Home > Technical > What suspension setting? |
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 |
I would say access mode is the best bet.
Fri Apr 13 2012 10:53pm |
jaca2865 Member Since: 02 Apr 2012 Location: Somewhere near you Posts: 10 |
Thanks Sag
Sat Apr 14 2012 7:48pm |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 |
in the official LR press releases, it states that the car will wake itself up every few hours and perform various tests. One will be to check if the vehicle is level. If not it will lower itself to try and level. Given that old suspension may have a slight leak, it would be best to set down to access level so that the system has least to do. |
Mon Apr 16 2012 8:44am |
