Home > Wheels & Tyres > Ordering a sett of 22"
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Hi!
I'm ordering a sett of 22" stormer for my 2006 HSE range rover sport and need some help.
I can choose between:
10x22 5x120,7 48 72,6
10x22 5x120,7 45 72,6
Im going for the 285/35/22.
Is this a good option???
Post #337570 Fri Mar 23 2012 3:02pm
shakeapaw
285/35/22 is what i have on my 22" 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #337574 Fri Mar 23 2012 3:35pm
Make sure the weight rating is over 1000kgs Thumbs Up
and the ET 45s would be that little bit further out and would look Cool RRS gone
Post #337575 Fri Mar 23 2012 3:37pm
RRSNorway
Thanks for great info!
So the offset is ok?
Post #337589 Fri Mar 23 2012 5:21pm
Standard offset is between 48 & 55, depending on style
I think the Standard Stormer is ET 55 so either 48 or 45 would look more aggressive Thumbs Up RRS gone
Post #337594 Fri Mar 23 2012 5:32pm
babylin
Choose this 10x22 5x120,7 48 72,6. This is much better.
You can see the difference.
Post #337885 Mon Mar 26 2012 6:11pm
Ballsy
Where did you order your wheels from? Good price?
Post #338105 Wed Mar 28 2012 6:04pm
RRSNorway
Got it from a norwegian dealer Smile £1300 for wheels and tire.
Post #338168 Thu Mar 29 2012 1:51pm
kahndesign
as long as you dont have the brembo brake calipers on yours then you should be fine with those
Martin
Post #338169 Thu Mar 29 2012 2:43pm
frankym3
Babylin seems to contradict previous advice by awd man?
Am thinking of doing this change myself next week, so wondered which is best? (Apologies for a hi jack!) Also if the 235/35/ 22 is the tyre, which I understand and the 45/48 is the offset, then what are those other numbers for????
Post #338943 Fri Apr 06 2012 12:57pm
RRSNorway
Hi guys!
After some time my 22" are starting to wobble after hitting a speed of 75-90 km/h
Tried balane 2 times and got the car check out aswell. Nothing wrong....
Any thoughts?
anyone knows the 22" stormer wheel tyre pressure 285/35/22? Could it be wrong/different pressure that makes the wobble?
Could it be the tires that are wrong installed?
Hope for some help:)
Post #347196 Sat Jun 16 2012 11:32am
Kensta
Sounds like dodgy wheels or tyres causing the wobble Norway if u havnt had them on very long Java black 2006
Post #347200 Sat Jun 16 2012 11:57am
RRSNorway
I agree;) could it just be the tires I bought? magby go for a 275 rather than my 285?
Post #347349 Sun Jun 17 2012 10:25pm
Kensta
It could be a dodgy tyre Norway but the difference in tyre width wouldn't cause a wobble, u defo shud not hav a wobble with new wheels and tyres mate take them back and tell them Java black 2006
Post #347360 Mon Jun 18 2012 12:16am
RRSNorway
finaly got the right balance.
Was perfect for 3 weeks but now it has stared to wobble after the first 2 min at 80 km/t. After 2 min its perfect again....
is this normal? is it because its getting warm and need so settle? RRS 2006 2.7 HSE
Post #350084 Sun Jul 08 2012 1:08pm
