![]() | Home > General > Newbie checking in! And looking for an RR Sport... |
you'll get better than 20mpg from the TDV8 (mine always levels off at 23-24)
Mike_C Member Since: 19 Mar 2012 Location: Bucks Posts: 184 ![]() ![]() ![]() |
Thanks awdman! Are those figures before or after your BAS map? I take it that is a remap of some form...?
Yes mine's had a Bell Auto's Re-Map and it was done within a month of getting the car |
Yeah I think one of the first things I'd do would be to remap the 2.7 TDV6! What sort of gains were achieved from the map by Pete?
That's very accurate! The commute is good for MPG, basically up the A5 from Bucks to Leics - in my 330Ci, which I usually get around 27-28mpg from in mixed use it returned 35mpg on that journey there and back! Which I thought was really good. |
Pete's map typically returns +40bhp and +100lbs torque which transforms the 2.7 into a much more eager motor |
Sounds about the same as Simon @ EMAPS - he will take it from 190bhp to 230bhp and 440Nm to 510Nm, so perhaps slightly more torque from the BAPS map? I bet a remapped TDV8 is pretty special!! ![]() |
I cannot comment on anyone elses map... I chose Pete because I wanted the flexibility of being able to upload the standard map back on if I needed to (dealership re-flashes etc)
