Home > Technical > Satalite Navigation speedsensor.
Garrie2283
Australia 2006 Range Rover Sport TDV6 S Rimini Red
Can anyone tell me where the navigation speed sensor is located. My navigation has suddenly developed a faultwhere it no longer adjusts to vehicle speed, in fact the map is scrolling through much faster than vehicle speed.
Any assistance would be appreciated as to date dealer has no idea.
Big Cry Big Cry
Post #331605 Wed Feb 08 2012 10:18am
chesterfield
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
I would have thought the speed would have been calculated from the communication with the sattelites.
i.e. the system uses its gps position to place you on the map, and the software onboard just calculates your speed based on the distance travelled over the time between refreshing the satellite position.
Sounds like you may have a faulty gps unit which is feeding the wrong position info to the sat nav, resulting in the system thinking you are much further ahead than you actually are.
I do not know where the GPS sensor is though. Is the car under warranty? If so they may look to change the whole sat nav unit if the gps locator is built into it. Failing this, a reflash of the software may help, but if its a faulty gps locator, then that may not help at all, and it would require a hardware swap out. RRS 3.0D HSE 11MY - Fuji White, a few extras.
Post #331633 Wed Feb 08 2012 12:24pm
