![]() | Home > General > I want my rrs to roar!! |
RRSboy will be along soon telling you that you need to get a V8 |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
poolie Member Since: 29 Apr 2011 Location: teeside Posts: 138 ![]() ![]() |
Change the record heard it all before Mr H and rrsboy a thousand times |
0cj0 Member Since: 23 Sep 2010 Location: York Posts: 290 ![]() ![]() |
The only way to really make it roar, is get rid of the cats and straight pipe it ... make sure you post vids if / when you do it |
Rather like taking the larynx out of a neutered feline.. |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
have you considered the mod offered by James LPR?
Baben Member Since: 14 Feb 2008 Location: Kyalami Posts: 29 ![]() ![]() ![]() |
Just decat it and replace with a straight pipe. That's the best the TDV6 will sound.
Ballsy Member Since: 19 Jan 2012 Location: Fife Posts: 160 ![]() |
+1 |
But then it will become an unroadworthy vehicle and fail its next mot |
felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203 ![]() ![]() ![]() |
Bear in mind you can only remove the CAT from vehicles up to chassis number 7a. At the moment it won't fail an mot, but!! New laws maybe coming in. If you buy a bolt on de cat pipe then as long as you don't mind swapping it back, that is if these new laws come in then it's never a problem. |
Not if you've got a friendly mot station ![]() |
+1 ============ 2010 TDV8 HSE - ooo laa laaaaaaaaa 2007 TDV8 HSE - superb car and very reliable ============ 2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8! |
is this expensive/hard to do? ============ 2010 TDV8 HSE - ooo laa laaaaaaaaa 2007 TDV8 HSE - superb car and very reliable ============ 2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8! |
Think a custom de cat pipe is around £90. then it's a case of unbolting the cat section and replacing the de cat one. Flange on the turbo end is a bit fiddly but apart from that an easy job. |
