Home > Faults & Fixes > Front and rear heated screens take ages to work
Armadillo
My 2008 RRS front and rear screens seem to take ages to defrost - is this normal?
The front heated screen takes about 6 minutes to clear and the rear one takes 10 minutes and one element near the base of the rear screen seems to be not working?
Is this normal. I bought it a few months ago and now its cold this is the first time i have needed to use them and just noticed it.
Post #328439 Tue Jan 17 2012 12:52pm
Front - normal Rear - not normal. 2005 Zambezi TDV6 - Gone but not forgotten
Post #328440 Tue Jan 17 2012 1:03pm
Front screen takes 6 minutes? Not normal in my experience. The front screen has been clearing in less than 2 minutes with -4degC outside. Are you directing air on it too? With the FBH, the air in mine is warm in about a minute and this really helps the front screen defrost. 2012 SDV6 - it's missing a couple of cylinders
Post #328468 Tue Jan 17 2012 4:05pm
Supacat
Agree 6 mins is not normal for me either. Closer to the 1-2 mins on the front and a little longer on the rear.
My previous RRS was slow sometimes. I have a theory that if you are running a high load on an idling engine and the battery is not in tip top condition there might be a power management function that cuts power to the most hungary circuits. Otherwise there is no explanation as to why sometimes it was slow and others it was not.
Post #328558 Wed Jan 18 2012 9:58am
Stuart's the man
front screen 2 minutes tops to clear
Post #329903 Sat Jan 28 2012 12:45pm
DrNick_B
United Kingdom 2008 Range Rover Sport TDV8 HSE Bonatti Grey
I reckon your theory is spot on!!!!
If I start my 58 plate RRS on a cold day and immediately switch on the heated front screen, it doesn't work!!
If I wait until a little puff of white smoke from under the front N/S tells me that the diesel engine heater has successfully started up and then switch on the heated front screen, it typically clears the screen in about a minute!
I've had the debate with JLR about battery and alternator performance on both this RRS and my previous one, but they don't go with out theory!!! lol
Post #370895 Thu Jan 24 2013 9:54pm
