Home > General > Sat nav and tv upgrade
Klinker
2006 Range Rover Sport TDV6 SE Java Black
Hi all,
My rrs 06 hasn't got the DVD day nav package and I'd like to add it,
Does anyone know exactly what components i need also would like tv tuner too is this a seperate add on also ???
Thanks
Matt Whistle
Post #327426 Mon Jan 09 2012 12:15pm
Klinker
Sat nav not day nav darn auto correct !
Post #327427 Mon Jan 09 2012 12:17pm
TBH cheaper & easier to sell your RRS and buy one with it included. 2005 Zambezi TDV6 - Gone but not forgotten
Post #327429 Mon Jan 09 2012 12:25pm
Klinker
Really ? That much of a mission, only downside to that idea for me is I've done a lot of mods to mine
Post #327430 Mon Jan 09 2012 12:37pm
RRS-Spy
Slightly at a tangent, how easy is it to add the TV Tuner if you already have a DVD based Sat Nav ? Proud owner of a 2008 TDV8 HSE.....and an Audi A3 2.0T DSG Cab and a Porsche 911 Turbo (Mercedes W208 320 CLK and Mercedes W124 E220 Estate now gone)
Post #327452 Mon Jan 09 2012 3:33pm
Fairly easy - from what I remember it's about a £800 job at a fitter - obviously cheaper if you diy. 2005 Zambezi TDV6 - Gone but not forgotten
Post #327454 Mon Jan 09 2012 4:19pm
RRS-Spy
Thanks.
Any pointers to sources of the part(s) and/or DIY instructions ? Proud owner of a 2008 TDV8 HSE.....and an Audi A3 2.0T DSG Cab and a Porsche 911 Turbo (Mercedes W208 320 CLK and Mercedes W124 E220 Estate now gone)
Post #327455 Mon Jan 09 2012 4:24pm
wiggs
for factory fit tv you need
tv tuner
4 x antenna amps
2 x antenna amps wiring looms
1 x coax cable from tv tuner to screen
1 x tv tuner bracket
then the tv has to be enabled in the ccf file ( this gives you the tv icon and tells the car its fitted ) ..unfortunatly the dealers cant do this ...but a faultmate diagnostic machine can
antennas are already built in the rear side windows
antenna amps and 2 looms are approx £250 from LR ...then depends on what you can get the tv tuner for Bluetooth Exchange www.bluetoothexchange.co.uk
Post #327484 Mon Jan 09 2012 7:56pm
RRS-Spy
tv tuner
4 x antenna amps
Thanks Thumbs Up
Are the wires already run to the rear window antennae ? Proud owner of a 2008 TDV8 HSE.....and an Audi A3 2.0T DSG Cab and a Porsche 911 Turbo (Mercedes W208 320 CLK and Mercedes W124 E220 Estate now gone)
Post #327488 Mon Jan 09 2012 8:20pm
wiggs
No ... There is a small fly lead on the antenna amp that presses onto a stud on the glass .
If you haven't got the studs on the glass ... The same studs can be found on a pp9 battery ... They can be stuck on with conductive glue Bluetooth Exchange www.bluetoothexchange.co.uk
Post #327498 Mon Jan 09 2012 8:53pm
oxford-boy
Any recommendations as to whom can do a retro TV tuner fit to a RRS with DVD sat Nav? 2005 Range Rover Sport TDV6 HSE in Artic Frost. 20" 2010 HST Alloys, sidesteps, Hawke tips, plus minor bits and bobs along with a remap. Four spike spiders ready for the Alps again now tucked up in their garage boxes...
Post #327519 Mon Jan 09 2012 10:44pm
Mr H
England 2009 Range Rover Sport TDV8 HSE Santorini Black
Car vision uk did my tv and DVD combo and it seemed reasonable, web site gives you prices Thumbs Up Have i got the busted controller?!?!!?
2009 RRS TDV8
Santorini Black
Ivory / Anigre
Privacy
DVD & TV
Side Steps
Post #327520 Mon Jan 09 2012 10:45pm
WEERAB
HELLO wigs,
just to say hope you got the Bluetooth module ok it working a treat
do you know where I can get the part numbers for antenna amps and looms
Quote:
tv tuner
4 x antenna amps
Post #413285 Mon Feb 10 2014 11:05am
HandsomeWeasel
so if the car has the rear entertainment, sat nav, dvd and analogue tv all factory fitted, how can you upgrade the analogue tv to digital? can that be done through a dealer?
Post #413294 Mon Feb 10 2014 12:04pm
WEERAB
you buy a digital tv tuner matey ok
Post #413301 Mon Feb 10 2014 1:25pm
