Home > Maintenance & Modifications > Renew ancillary driving belts
lesmon
Trinidad And Tobago 2006 Range Rover Sport Supercharged Bonatti Grey
Hi all,
I have migrated from the UK and exported my trusty 2006 RRSPT 4.2 V8 Supercharged with me to the Caribbean. Recently had to replace the battery due to a dead cell. Soon after replacing the battery, the alternater/battery light came on interminently. I have been monitoring this for a few days now - and it does not come on at first start and could stay off for up to 10 mins before coming on and staying on. It seems that the alternator is charging the battery and while charging the battery light is not on - but when the batter reaches full charge the battery light will come on. I have swapped batteries with another, and the same problem occurs so it is not the battery.
I have tested the voltage at the battery and get the following results:
engine off: 12.5 volts
Engine on (no red battery light) : 14.5 Volts
Engine on (red battery light on): 13.7 volts
Alternators are generally repaired here - i.e replace brushes, diodes, bearings, regulators, etc. To have it repaired I need to take it off the RRSPT. I have a copy of the 4.2 Generator removal (86.10.02) which I downloaded from this site (from Bob, I think). This looks simple enough. I also had a look under the vehicle at the alternator and noticed that I have 2 belts - the supercharger drive belt, and the ancillary drive belt. From where I looked, I think I saw the 'tensioner' for the ancillary drive belt but uncertain of how it operated or would allow me to take the belt off.
To take of the accessory drive belt I think I need a copy of 86.10.03 for the 2006 RRSPT Supercharged.
Can one of you helpful chaps post a copy of the information, please + any other hints and tips that could get me going.
PS. I am pretty handy with tools and cars mechanics - just need to know how Smile
Thanks. Totally Supercharged!!!
Post #327344 Sun Jan 08 2012 9:38pm
Bobby
HERE you go. Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #327357 Sun Jan 08 2012 11:12pm
lesmon
Superb and Thanks, Bobby!!
Any chance of the Cooling Fan Belt (26.25.01) instructions as well?? Totally Supercharged!!!
Post #327368 Mon Jan 09 2012 12:35am
Supacat
Removal
Installation
Published : Jul 28, 2004
1 .
Disconnect the battery ground cable. For additional information, refer to Specifications (Section 414-
00)
2 .
Coupling unit - viscous fan -renew For additional information, refer to Cooling Fan (26.25.19)
(Section 303-03)
3 . Remove the cooling fan drive belt.
Using a 1/2 inch square drive bar, rotate the drive belt tensioner clockwise.
Post #327397 Mon Jan 09 2012 9:15am
Bobby
Cooling Fan Belt  Malaysia Boleh!
Post #327502 Mon Jan 09 2012 9:19pm
lesmon
Cooling fan
hi Bobby,
Decided to try this today and realise I need this as well: Cooling Fan (26.25.19) Totally Supercharged!!!
Post #337677 Sat Mar 24 2012 2:29pm
Bobby
Do a search! Wink
THISis already in my Gallery! Laughing Malaysia Boleh!
Post #337706 Sat Mar 24 2012 9:29pm
