Home > Technical > new sus compressor noisy
Maxrrsport
2006 Range Rover Sport TDV6 HSE Siberian Silver
Hi all,
Ive been getting a fault on my 2005 tdv6 with my suspension not wanting to do anything, blowing fuses, yellow fault light etc so Ive decided to change the compressor with a brand new unit from landrover. fitting was simple but ive started the car up and the compressor is making a strange wurring noise. It now has no fault lights and is moving to all selected heights as required but just making noise, Ive only had it on for a few minutes to check the fault had gone which thank god it has, any help with the noise guys as I dont want to drive it if im going to damge the new compressor.
Thanks
Max
Post #325945 Wed Dec 21 2011 8:48pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
First guess would be it sounds like the compressor can't get the air system up to pressure so its running constantly..... check for leaks..... Some fairy liquid in a skooshy bottle and spray it on all the connectors, ull soon find any leeks
or possibly an issue with the pressure switch, either you have the wiring round the wrong way or its faulty.
Post #325948 Wed Dec 21 2011 9:07pm
Maxrrsport
Hi Thanks alot for your reply it turns out I was worrying for no reason, I had it set to off road height it hadnt fully reached it as soon as it did it didnt make any more noise, been up and done a few times and working a treat now.
Thanks again
Max
Post #325950 Wed Dec 21 2011 9:24pm
Bobby
Whilst changing to a new compressor, it is also recommended that the dryer be replaced and the air suspension control software is updated at the same time. Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #325966 Thu Dec 22 2011 6:08am
