![]() | Home > Technical > Wheels that will fit? |
maddogsetc Member Since: 03 Sep 2011 Location: Hampshire Posts: 51 ![]() ![]() |
Bought a set of 19" FFRR wheels for SWMBO's RRS but seems they won't fit over the calipers |
Thanks RRSTDV8, that's good news. Presumably the V8 would have bigger calipers if anything |
Mr H Member Since: 09 Sep 2011 Location: Lincs Posts: 427 ![]() ![]() ![]() |
+1
rr5port Member Since: 08 Jun 2011 Location: Northampton Posts: 43 ![]() ![]() |
19's or 20's, just make sure that they are 9.5J and they'll fit over Brembos no problem |
Thanks folks, how do I tell if they are 9.5J? Is it cast onto the spokes? |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5642 ![]() ![]() |
Should be marked inside wheels |
Thanks |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
9.5j bit wont make any difference if the offset isnt correct ...... offset of ET as its stamped on the wheel should be on the back of the wheel. RRS and FFRR have different offsets if i remember correctly but i would have thought that the ET of the FFRR would be higher than that of the sport.
They look the same wheel I have fitted for winter - they are also 50 profile as required - discos usually have 55 |
Definitely foul, they showed me whilst it was on the ramp and it wasn't possible to push the wheel back into contact with the hub. Sorry for being thick, what is ET? ![]() |
ET is the distance in mm from the mounting face to the centre of the wheel this picture will kinda help to explain ![]() As suggested spacers will help resolve the issue , or just buy the right wheels. |
Thanks for the explanation |
ON the founting face ull see ET listed
CeeJay4Fun Member Since: 22 Nov 2011 Location: Ystad Posts: 56 ![]() ![]() ![]() |
IF the offset is 57mm for the FFRR then that would say that the center of the rim would go "in" 4mm more? In difference to RRS with 53mm not going "in" as much... and then if rim is curved then those 4mm could make calipers touch rim??? I have no clue... Just learning... and waiting on a message that some Scorpion tyres have M+S on them... ![]() Volvo V60R D5 2011 Black Jaguar XKR Cab 2002 Blue Polaris Ranger 800HD Green John Deere 6430 Premium 2009 IVT, GPS, Very green Volvo L30B Pro 2012 Yellow |
