Home > General > Is cold weather heater working ? |
rockhoppers1964 Member Since: 26 Apr 2011 Location: Dunfermline Posts: 39 |
How do i test to see if the diesel heater in the engine bay is actually working.
Thu Dec 01 2011 12:33pm |
DrRick Member Since: 24 Oct 2011 Location: Edinburgh Posts: 54 |
If you get an answer, let me know as I have the same query. Unless of course its a better heater exhaust than the D4 that spews steam! Takes me a good 10mins driving before the temperature needle moves.
Thu Dec 01 2011 2:35pm |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
It should be obvious
Thu Dec 01 2011 4:24pm |
felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203 |
Mmmm i've always wondered about the FBH on mine. Its there, but doesn't say anything in owners manual and as far as i know mine doesnt work. Why put it there if it doesn't work!?? Or are they prone to just break down after the cars a couple of years old. |
Thu Dec 01 2011 5:05pm |
On a 2005 car it may well have a fault..
Thu Dec 01 2011 5:14pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Of course, one can also check by driving for a few of minutes on a suitably cold morning, stopping, opening the bonnet and carefully checking for warmth from the FBH. It's obvious (without touching it!) if it's been running. 2012 SDV6 - it's missing a couple of cylinders
Thu Dec 01 2011 5:16pm |
Possible cause is stored faults in the unit... you need to do a soft reset..
Thu Dec 01 2011 5:22pm |
Haa typical!! The Wifes left it with the fuel light on so i can't see if the reset method works! It'll have to wait till another day. |
Thu Dec 01 2011 5:52pm |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 |
Mine was working today, i could here it from inside but still jumped out to check.
Fri Dec 02 2011 12:49pm |
Done the soft reset this morning. All working fine now. |
Tue Dec 06 2011 6:30am |
Southern Jock Member Since: 02 Nov 2010 Location: Newbury Posts: 69 |
Me too, thanks guys |
Tue Dec 06 2011 8:22am |
RRS gone
Tue Dec 06 2011 9:03am |
bigleigh Member Since: 22 Nov 2011 Location: leeds, West Yorkshire Posts: 8 |
Glad I read this now as I've only had car couple of weeks and got a bit concerned when smoke started bellowing from engine bay, rung garage today about it and he basically said what you guys are saying, so I know he's not pulling my leg. When it first happened I thought car was on fire lol. Is it normal for lots of smoke or is it just cos it won't of been used for a while? |
Tue Dec 06 2011 10:18pm |
totally normal RRS gone
Wed Dec 07 2011 8:28am |
