Home > General > URGENT FAULT HELP NEEDED. VERY WORRIED |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
Yep, wouldn't worry too much. When I had a D3 the rear light bulbs failed regularly, which in many cases (as reported on the Disco site) threw up loads of error messages. I replaced them with leds which were fine. But voltage irregularities can cause histrionics with the computer!! |
Mon Oct 24 2011 9:43pm |
jrinns Member Since: 10 Dec 2010 Location: Midlands Posts: 88 |
Garage just called, they cant get access to the code, dont know what this means , dodgy HDC ECU ? anyway they want another hour of diagnositcs as the engineer thinks he can get to the bottom of it ! Hi-tech systems my arse... |
Tue Oct 25 2011 10:34am |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
If you intend to keep the car get yourself 009 hawkeye reader. Plug it in and this will read all your faults etc and you can reset them if you need to. Saves money in the garage where they naff around at 70 an hour!!! @£300 it will pay for itself over time. |
Tue Oct 25 2011 12:46pm |
