Home > Maintenance & Modifications > Wind Deflector/Visor
Alexelluk
Scotland 2009 Range Rover Sport TDV8 HSE Stornoway Grey
I am looking to fit wind deflectors to the passenger and drivers window and would appreciate any advice whether to get stick on deflectors or the clip-on deflectors. I have read that the clip in ones can cause problems with the seals, etc Exclamation Question
Post #309939 Mon Aug 15 2011 5:38pm
Jimmy_75000
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Shocked why would you want to put that on such a nice car??? Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #309952 Mon Aug 15 2011 7:07pm
Tail End Charlie
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Isn't that technically vandalism? Crying or Very sad
Post #310068 Tue Aug 16 2011 12:36pm
Tim in Scotland
Alex, don't listen to this lot of heathens................ your local LR dealer or one of the forum sponsors will supply you with LR's own ones designed to work properly on your RRS if you really have to have them! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #310075 Tue Aug 16 2011 12:51pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Had clip in ones fitted for nearly 3 years. Front ones all the time rear only in winter months.
No problem with seals Thumbs Up On odd occassion did cause the window to go down instead of up.
Reason rears only fitted in winter caused slightly more wind noise about 65-70mph.
Having had the stick on landrover ones before on Disco can confirm they are quiter than clip in ones, but once on thats it.
With clip in ones noise reduced when driving with window slightly open and stopped rained and windscreen wash cominmg and going all over the window switches
Post #310186 Tue Aug 16 2011 7:21pm
