![]() | Home > Technical > Reversing camera wrong way round |
rabbutler Member Since: 11 Dec 2009 Location: Aberdeen Posts: 187 ![]() ![]() ![]() |
Never looked at the nav screen at the picture from the reverse camera before until this lunch time when i went out. Bloody hell had to brake really quickly because thought I was about to hit something. Everything appears on the screen on the opposite side, if I am reversing into a space so the passenger door is at the kerb, the pavement appears on the right side of the screen.
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 ![]() ![]() ![]() |
This is a fault Rab ! Your dealer should fix it under warranty... I know i had the aussie cam too ! |
Thanks fox.
Yep Everything was just on the wrong side of the screen... |
wiggs Member Since: 27 Apr 2007 Location: Manchester Posts: 99 ![]() ![]() |
Normally if the camera gets inverted the yellow lines disappear as well Bluetooth Exchange www.bluetoothexchange.co.uk |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 ![]() ![]() ![]() |
Which means that if You have the camera inverted,
