Home > General > Sidelight problem
carricklad
Sidelight problem
Noticed my driver side bulb wasn't working, so thought i would get led bulbs, fitted them and still not working driver side, so checked fuses (2&4 slot in glovebox) changed them still not working, passenger working fine, swapped bulbs also as knew passenger side was ok.. Still nothing.. Any ideas Sad ?
Thanks
Gary
Post #306389 Sat Jul 16 2011 4:52pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Headlights working?
Have you checked the switch?
Post #306391 Sat Jul 16 2011 5:37pm
simon1233
Have you checked the bulb in the drivers sidelight? LED bulbs are sensitive to polarity and will only work in one orientation. Take it out, rotate by 180 degrees and reinsert. See if that helps Thumbs Up
Post #306396 Sat Jul 16 2011 6:35pm
AndyKay
carricklad did you ever get this sorted? I've noticed this on my car (passenger side) - thought it was just the bulb, changed, still not working, checked fuse and that was OK.
Headlights work fine. RRS HSE TDV6 Autobiography
Post #334638 Thu Mar 01 2012 10:59am
