Home > General > Extenden warranty
Sach
2007 Range Rover Sport TDV8 HSE Stornoway Grey
Extenden warranty
I own a 57plate TDV8, which I purchased last august from a dealer, therefore supplied with one years warranty. I received a renewal notice for the LR warranty today, quoting £780 or £890 including LR Assiatance. What do you all think - should I take this up, can I shop around, if so where? The car has done £32 miles and I only cover only about 8k miles a year mainly urban driving (18 mpg Big Cry ). I am tempted not to renew and pay if and when something goes wrong, likelyhood? Your help and comments will be much appreciated.
Post #303654 Wed Jun 22 2011 6:02pm
drdelrrs
You need to take a dispationate view of both your car and you as a driver.
1. How does your car run? engine smooth, gearbox smooth, unuusal noises. etc etc. Any sign or seepage of any oil/fluid whatsoever anywhere it should not be: axles. Give it a good once over and decide, in general if you went out to buy it would you?
2. Do you drive with mechanical sympathy or do you accelrate hard, brake hard, hit kerbs, use high revs from cold etc. Have you needed to replace worn out tyres, brake pads etc etc; at 32k probably not or only just.
The answers will give you a good idea whether you're likely to need to spend money on repairs - usually a well treated motor will treat you well. Personally, if tis all A1 at the moment at 32k miles I'd take a chance you'd get another 100,000; my previous RR did 150k, needed only 3 sets of tyres and 3 sets of front pads, 2 rears.
Don't forget when you read a forum like this it is the problems that get under most people's skin so that's what you'll read most off. I had RR's since 1975! often more than 1 at a time)and done most things with them that are possible. Usually kept for about 90k or more. Only issues were a broken oil pump drive on a V8 3.9 petrol, a transfer box under warranty on a P38
Post #303662 Wed Jun 22 2011 7:12pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
you'd be mental to drive it without some sort of warranty ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #303676 Wed Jun 22 2011 8:40pm
