Home > General > Not sure what to do? |
When i changed my private plate over i went to my local DVLA office and they gave me my new tax disc there and then, correct me if i'm wrong it is noted on the DVLA database that there is a change over in place and they allow a few days grace to allow this to happen, previous to this with my other vehicle i was told that i could use my current tax disc until my new tax disc arrives in the post, so my plates said one thing and my tax said another, but make sure your insurance is for the plates you are using on the car at that time, otherwise you will get tugged for not having insurance, so the answer is yes you can use your old tax disc till your new one arrives unless the law has changed again recently.
Sat Jun 11 2011 6:32pm |
The whole process has changed I found out when putting my private plate on the RRS.
Sun Jun 12 2011 9:22am |
timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235 |
I just run on the private plate with existing tax disc as any check ran will highlight both number plates taxed linked to same vehicle, I have done this about eight times now and never any problems. |
Sun Jun 12 2011 12:53pm |
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 |
You usually receive the new tax disc & number plate authorisation certificate before the log book comes back!!! |
Sun Jun 12 2011 12:54pm |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 |
You CANNOT put the plates on untill your new tax disk arrives,I bought my plate a couple of months ago and it clearly stated that on the paperwork. |
Sun Jun 12 2011 1:14pm |
Full explanation here
Sun Jun 12 2011 2:48pm |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 |
Mmmmmmm................ Think I might leave it in the garage until I receive everything as I have already changed the plate over!! Thanks guys! Cheers Laurence. |
Sun Jun 12 2011 7:11pm |
Sabre1966 Member Since: 31 Mar 2011 Location: Essex Posts: 94 |
I called in to the dvl a office in Chelmsford and they swapped it for me there and then! |
Sun Jun 12 2011 7:37pm |
Mitch6176 Member Since: 31 Jan 2011 Location: Edinburgh Posts: 47 |
To back up a couple of the other posts above, take your new V5 log book and you're "old" tax disk to your local DVLA office and they should swap old for new there and then.
Mon Jun 13 2011 7:52am |
As above, they will also give you a new mot certificate if applicable so take your old one with you aswel. But if you've already sent it off in the post and you have the log book with the new plate details which you say you have then i would run the vehicle with the old tax disc, i was told i could do this in the past, until the new one arrives, at the end of the day your vehicle is taxed one way or another and the police will know this if dvla have updated their records. |
Mon Jun 13 2011 8:01am |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
+1 , Yep, Exactly what I did too. Get yourself down to your DVLA office and they will sort it for you 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Mon Jun 13 2011 11:07am |
