Home > Technical > Damaged a rear tire, tires are at approx 50-60% what to buy?
Frosty_Power
Canada 2006 Range Rover Sport 4.4 V8 HSE Alaska White
Damaged a rear tire and it is not repairable. My tires on it now are still somewhat usable and decent, maybe 50-60%. I know you should buy all four tires when dealing with AWD and 4x4's. Do I or should I buy new tires all around? Buy just 1? I know I should buy all 4 but I do not want to spend all that money if I do not have to at this point. I'm running Toyo Proxies S/T's(275/40/20 106W) and are quite expensive($375CDN each) and I've found a pair of used Continental Sport Contact(which are on some RRS's from the factory)(275/40/20 110H) that are about 60% also for a good price. Would this work until my fronts wear out and then buy 4 tires next year?
Thanks in advance.
Post #302253 Wed Jun 08 2011 3:36am
Timf
I had the same prob. Get two new ones, dont need four. I went for Pirelli
Post #302278 Wed Jun 08 2011 11:34am
Bradders
Just go for 2 as Timf says.
I remember reading somewhere that its important to keep the tread depth similar on the same axle, but there's certainly no need to change all 4. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #302281 Wed Jun 08 2011 12:00pm
erfec10
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
got 2 new tyres from mytyres,posted free to my door,275 by 20 by 40 106 load w speed.£91 each plus vat.Hancook.Use them on my lorries and never had faults.
Post #302337 Wed Jun 08 2011 8:27pm
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
who told you to replace all the tyres...your car is a proper four wheel drive not one of those little AWD thingys that are so fragile...I would just replace the one that was punctured unless the other one on that side needs replacing.
Post #302350 Wed Jun 08 2011 9:57pm
mse
It does recommend in the book replacing all four.
Personally always replace in pairs (unless there is only a small number of miles difference) Mike
2014 Facelift Discovery
Post #302360 Wed Jun 08 2011 11:11pm
