![]() | Home > Off Topic > Sunroof |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
Just wanted to say how good it is to have a sunroof......never had one before and in this glorious weather it really is a treat, I used to think what is the point, but would urge anyone speccing a new vehicle to get one
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
I don't often open mine but the extra light is a must
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
I dont like the sun shining in onto my head,it gets to hot,mind you I remember many years ago cutting holes in car roofs and fitting sunroofs when I was 17/18,,the type that you put the glass in the boot if you wanted it open completely |
gilford Member Since: 07 Jan 2010 Location: Anglesey Posts: 542 ![]() ![]() ![]() |
Never used mine, I hate wind |
edvarski Member Since: 08 Feb 2011 Location: Knaresborough Posts: 19 ![]() ![]() ![]() |
If you want to get rid of the buffeting, open up the sunroof on the tilt setting - it gets lots of fresh air through without much noise.
If you open your front windows just a little bit it stops the buffeting noise, and if you just want your drivers window open only, just open the rear window a little bit on the same side of the car, it stops the wind blowing straight onto your face. Try it and see. ![]() |
