Home > Technical > Logic 7
PaulB
Logic 7
Does anyone know if it is possible to retro-fit Logic 7 to a HSE spec car that didn't have Logic 7 factory fitted?
I know there are some extra speakers in the rear roof lining, but apart from that, everything else appears to be the same. Is there a possibility that the Logic 7 bit is simply a software upgrade ?
I had a loan D3 that had L7 and it sounded noticably better than the standard "Premium" kit in my RRS. Crying or Very sad
Paul
Post #28397 Fri Apr 28 2006 12:59pm
I doubt it, Paul. I'm no AV buff, but I expect the extra processing to perform all the 5.1/7.1 trickery is in hardware as opposed to software. I'm sure someone can give a much more comprehensive answer.
Post #28404 Fri Apr 28 2006 1:11pm
Paul, I think there is also something like double the number of speakers, not just a couple in the headlining.
I agree though, I find the sound a bit tinny despite turning up the bass and down on the treble.
Works well though on good bassy sounds but you're not always playing these so............ Runner up - 2009 Best Avatar Award Sad
Post #28440 Fri Apr 28 2006 2:06pm
Josh
Sorry Paul, can't see L/R sticking in a better head unit for free that can be upgraded with software. Have you asked the dealer yet? TDV6 - gone
TDV8 - gone
Post #28458 Fri Apr 28 2006 3:11pm
grommet
United States
The head unit is the same. The amplifier is different. (As is the infotainment system software. If you have the "wrong" software installed, it sounds like total garbage.) The Logic 7 processing is done in the amplifier.
Personally, I think Logic 7 processing sounds poor and I leave it off most of the time.
Post #28490 Fri Apr 28 2006 5:27pm
PaulB
In which case grommet, I'll gladly take your Logic 7 amp off your hands Very Happy
Where is the amp and could it be swapped out for the Logic 7 unit ?
Paul
Post #28508 Fri Apr 28 2006 7:38pm
Cliff H
I think it is under the drivers seat, it is in my 'premium' D3 anyway Rolling Eyes
Post #28516 Fri Apr 28 2006 8:58pm
RAD
Scotland 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Although I've got Logic 7.....the sound with it switched out, is far better. I have had the software "updated" (the amp is under the drivers seat) 3 times, all without success. LR are aware of the problem, but don't seem to have a working answer. The problem doesn't affect all cars with it fitted, but quite a few.
Save your money.....get your get chipped, that really makes a difference!
Post #28629 Sun Apr 30 2006 9:16am
I have it in my car and it sounds great but like RAD said it's doesn't affect all cars RRS TDV6 Gone but still around
Post #28644 Sun Apr 30 2006 9:48am
PaulB
Already been done by JE, and you're right, it makes ahuge difference Smile
Paul
Post #28737 Sun Apr 30 2006 9:19pm
Peter
United Kingdom 2006 Range Rover Sport SDV6 Autobiography Java Black
I have Logic 7 fitted and it really sounds the mutts nuts!
There is an option to turn it off (just after the sub woofer settings screen) and I hate the sound it makes when its switched off.
Maybe I was just lucky and got a good one!
I know that Angels RRS was behind mine on the production line so the odds are he's got a duff one!! It's finally gone! Replaced with BMW 730SE in Sophisto grey Xirallic finish with Oyster (Ivory) and black interior. DAB, Climate glass, Ceramic iDrive and gear selector, power boot and iPhone Bluetooth pack - luvvin' it!
I miss my old RRS "bucket" rattling around but it just had to go!
Post #29517 Wed May 03 2006 5:39pm
RAD
To put it in perspective, if you have a duff Logic 7............its a relief to switch it off and listen to the standard setting. If its bad, its really awful. They’ve changed the amp twice, re-loaded the software three time. Maybe if I went to church........?
Post #29614 Thu May 04 2006 8:34am
grommet
United States
For me, I don't like the Logic 7 processing effect on most content. It isn't defective... it even sounds about the same on RRS and LR3. I just don't like it. (I'm sure some may.)
So, for the people that think they have a defective Logic 7 stereo... Have you been in an identical Logic 7 equipped RRS or LR3 that sounds good to you? (Same bass/treble/sub/balance/fader settings, etc.)
Post #29638 Thu May 04 2006 9:00am
RAD
I had Logic 7 in my BMW 645 which sounded wonderful, that's the reason I specified it. Driven in other RRS's that work just fine......one problem is the programming, each time its re-done, everything changes, but after a few days the improvements just melt away like.....er, sorry, just having a a senior moment. Anyway, its obviously a software problem, but no trace of getting the right answer - yet!
Post #29675 Thu May 04 2006 9:30am
