![]() | Home > General > Reversing Sensors |
Did you try hitting this switch..
ray.finch Member Since: 17 Nov 2010 Location: Surrey Posts: 21 ![]() |
Hi Bobby Yes I have done that but then found they dont come back on automaticly when you next go into reverse, last time I did it, it cost me £120 for the dink repair where I cought the car behind (wasn't happy lol) Ray |
Your problem is not with the rear sensors but the front ones not switching off since you have not reached the required speed. In such situations one presses the above mentioned switch to deactivate the front sensors. However, the whole system should come back on when you next select reverse.
Bobby, your knowledge has no bounds |
