Home > Technical > range rover supercharged gearbox problem
gc
hi i have a range rover supercharged done 65k which has developed a gearbox problem,its fine when driving at normal speeds but when you give it some stick or use the kick down it sticks in 3rd gear and the only way to get it to change is knock it into sport then back into drive,had oil and filter changed but still the same,any help would be great,thanks
Post #297781 Sun May 01 2011 7:29am
