Home > Maintenance & Modifications > Door mirror glass
Warren G
Door mirror glass
How do i replace, do they just snap out???
Post #297166 Sun Apr 24 2011 8:18am
Warren G
anyone?
Post #297195 Sun Apr 24 2011 5:21pm
kieltdv8
Scotland 2007 Range Rover Sport TDV8 HSE Java Black
Hi
yes they just pull off with a bit of force
if you push your fingers up behind the bottom of the glass and pull it should pop off
if the glass is broken wear some eye protection
be careful replacing the new one because the retaining lugs are quite easily broken
and remember the heated mirror connection
cheers Kiel
Post #297196 Sun Apr 24 2011 5:29pm
NickM
many on here have tried without success - my advice is to take it to the dealers, give them £10, job done - otherwise you may end up breaking it...
Post #297199 Sun Apr 24 2011 6:49pm
GPN
Australia 2008 Range Rover Sport TDV6 SE Java Black
I HAVE USED A HOT AIR GUN (OR A good hair dryer) to heat up the glue holding the glass with success,to remove the mirror.
Post #297230 Mon Apr 25 2011 10:50am
