Home > Technical > Slight jolt after braking sometimes help
Jimmy07
United Kingdom 2007 Range Rover Sport TDV6 HSE Bonatti Grey
Hi members just noticed this on my 07 rrs hse when braking
Coming to junctions lights etc not every time and not up and down hill just seems of flats go to brake stops fine then just as going to stop and then seems to slightly jolt at the end would be greatfull if anyone has a clue what this could be please help
Post #296555 Tue Apr 19 2011 5:35am
Bradders
Mine does that too. Stopping in 2nd and there's a noticeable 'shunt' just before the car stops?
LR found nothing wrong with mine - but im not convinced. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #296557 Tue Apr 19 2011 6:43am
Some say a gearbox flush will help this (Even though LR say it's not required)
Mine is currently the same.... was a whole heap better after I had the module updated, but has gradually come back and after my rock encounter I think the tracking is out (that also creates rough gear shifts I've noticed) RRS gone
Post #296565 Tue Apr 19 2011 7:55am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Mine does exactly the same thing, not all the time, but it is a strange sensation. Not enough of a problem to worry about at the moment. Would be interested to hear what causes it?
Post #296568 Tue Apr 19 2011 8:08am
Jimmy07
Yes seems like I'm not the only one then
Could be a common problem by the look still would
Like to no what causes it tho as it is well anoying !!!!
Post #296740 Wed Apr 20 2011 5:21am
Stocko
I have a problem nearly the same and wonder if anyone else has , when I come up to a junction and say someone flashes me out before the car comes to a stop I sometimes get what can only be described as a bang like a false neutral for a split second but it does it 1 in 30 maybe dealer can't fault and have upgraded the software but it's still the same
It's a 07 TDV8 sport
Cheers Andy
Post #297425 Tue Apr 26 2011 10:05pm
Jimmy07
Mine not done it since I mentioned it !!!!
Post #297441 Wed Apr 27 2011 6:04am
