![]() | Home > General > fuel consumption on rrs 2011 diesel |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Sorry, nope! FF 4.4 V8 Soooo looking forward to this bad boy
22-24 is normal for the diesel RRS - outstanding if it's a petrol RRS though! |
Also if it is driven mainly in town the gearbox ECU may need some re-educating to make it go into 6th gear if you don't get the speed above 55ish most of the time. Once you get up to 55/60, move the gear stick to the left into Sport mode and then notch it forward once and the digital readout on the dash should show 6, come back out of Sport mode (which locks out 6th) into D and she should stay in sixth. Everytime for the next few runs where you are getting up to 55, try manually shifting into 6th and then the ECU will get the message and do it automatically. I had this problem when I took delivery of my FFRR, it had led a life of indolence trickling through London traffic for a few months and wouldn't go up to 6th with out manual intervention - now it shifts up by itself at 50-55mph with no manual shifting 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
I'm getting about 32 mpg on a long motorway run but about the same ie 25 mpg running around town. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Is it a new one??
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
mine is average around 25.8 mixed miles done about 1500 miles. SVR 2018 in Santorini Black. |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 ![]() ![]() |
My average over 1500 miles on A and B roads and round town, no motorway driving is 27.5 mpg.
Next time you go on a run, reset the computer and you will fine it is doing more mpg, but if you leave the computer it averages the mpg over you entire journey a+b roads + your motorway run and you will find by resetting your computer before you join the motorway it gives you a better mpg figure as it is averaging your new reset at higher speeds. ![]() |
Col10 Member Since: 18 Apr 2011 Location: Worcestershire Posts: 2 ![]() |
....... and don't start checking up on the fuel computer, wished I hadn't!
agreed, the mpg on the computer can be slightly optimistic....
Its all about the way it calculates it to how you calculate it using actual values
..... well my RRS certainly doesn't calculate it on fuel used and miles driven!
BulletProofBomb Member Since: 12 Jan 2010 Location: Lanarkshire Posts: 164 ![]() ![]() ![]() |
Ahh, ![]() ![]() Suzuki Bandit 1200 (For when the suns out) Nissan 350z GONE |
Its mainly because they use percentage of fuel in the tank based on the inaccurate float
