Home > Technical > Cruise control working intermittently , Any ideas pls? |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 |
Mine did this and over the course of a year I finally managed to get it fixed (under warranty thankfully). Problem used to be cured by a system reset (stopping and restarting the engine).
Thu Apr 14 2011 8:03am |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 697 |
Bugga mines not under warranty. |
Fri Apr 15 2011 7:35am |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
The clock spring on these is a well known fault, not that expensive, and from your symptoms sounds like a classic case |
Fri Apr 15 2011 1:26pm |
Whats the clock spring? How do I get that fixed? |
Fri Apr 15 2011 1:59pm |
strusal Member Since: 09 Mar 2011 Location: lonodn Posts: 5 |
My 2006 Sport cruise does the same. The cruise will work fine for a while then will just stop. Turning the engine off will sometimes work but not always. Had it looked at last year but the cruise worked fine for the mechanic and he couldn't find a fault on the computer. Really frustrating. Joyfully it has just developed an air suspension fault (after driving through the wilds of North London !) leaving the suspension fully lowered giving a really bouncy ride. I will be booking it in for a double service. |
Mon Apr 25 2011 3:01pm |
Mite b a sensor problem with yor suspension strusal I've heard it's common with the earlier models apparently |
Tue Apr 26 2011 8:06am |
colin107 Member Since: 26 Feb 2011 Location: essex Posts: 2 |
Hi
Thu May 05 2011 4:12pm |
gruodiz Member Since: 27 Nov 2011 Location: Klaipeda Posts: 63 |
simon1233
Sun Mar 17 2013 6:23pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
The man knows his stuff Common issue, and a new loom is around £15, and takes 10 mins to fit |
Sun Mar 17 2013 9:32pm |
Which wheel did he mean?
Sun Mar 17 2013 9:37pm |
Which loom costs 15GBP you're talking about is that clock spring?
Wed Mar 20 2013 6:58pm |
The loom in behind the airbag in the steering wheel |
Wed Mar 20 2013 8:42pm |
