![]() | Home > General > suspension fault and uneven rear tyre wear |
Could you refit your standard wheels and try them to see if the symptoms are there? Mike
tiggybelle Member Since: 27 Jul 2010 Location: united kingdom Posts: 26 ![]() ![]() |
Hiya
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 ![]() ![]() ![]() |
Hey Tiggybelle
Hey
Do you have an extended warranty? If you do it would it be worth putting the standard wheels on then if it persists taking it in to dealers? |
No I don't Have an extended warranty ... Range rover put dome 20" on when I had the knocking noise when i cornered to do some testing ( well they said they did ) |
Thats what i was getting at...if you take the tyres off then they cant blame them ![]() 2014 Facelift Discovery |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
hello Tiggybelle
jules660 Member Since: 25 Apr 2012 Location: devon Posts: 16 ![]() ![]() ![]() |
Hi All
pjb Member Since: 04 Mar 2008 Location: Sunny Oxon Posts: 213 ![]() |
Hi,
Thanks Paul |
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 ![]() ![]() ![]() |
I don't claim to be an expert either but when I had mine four wheel aligned I was not aware of any ECU reset or anything ike that done as part of the process. I would ask them why they think they need to do this - or potentially phone around somewhere else and see if they say the same thing.
Thank you Pat thats a great help i will check to see what system they are using
Hello jules
