Home > General > Knocking Noise - Front Left Hand Side
chapman_i.t
2005 Range Rover Sport TDV6 HSE Java Black
lo all,
I know this topic has been mentioned before....
I have a slight knocking noise coming from the front left hand side, not sure if it is the bushes or the link arms.
The noise isnt there on flat roads, but any kind of uneven or pot holes and there is a knocking noise from the front left hand side. I had this on an X5, and it just turned out to be a Link Arm.
Will Land Rover replace the bushes even if out of warranty because this is a common faulty, or have I mis-read that bit?
Any information would be appreciated.
Thanks
James
Post #290913 Wed Mar 02 2011 10:51pm
Jimmy_75000
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I don't recall them doing it for free if out of warranty mate... Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #290951 Thu Mar 03 2011 7:35am
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
I don't think it would be done for free if vehicle is out of warranty. Unless there has been a recall and your vehicle falls into the recall catagory.
The dealer & LR for that fact could just argue normal wear and tear, depending on age and mileage etc.
Post #290965 Thu Mar 03 2011 8:40am
chapman_i.t
Ok guys,
Does it sound like the bushes or just a link arm?
Thanks
James
Post #291013 Thu Mar 03 2011 2:02pm
Mines just started knocking... (well, one knock... when reversing on full lock then driving forward on the other lock)... dealer said most prob bushes RRS gone
Post #291015 Thu Mar 03 2011 2:14pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Mine's more like a rattle,was aware of the issues with arb bushes and drop link arms when I bought it so thought it would be one or more of those.However I have had it at a LR specalist who says it is none of the usual suspects and it is one of the best he has seen for being mechanically sound re.age 06.Everything is ok or has been replaced but I was aware of that because of service history and print outs,but its nice to be confirmed by someone other than the seller. Thumbs Up But anyone any ideas re. this rattle?
Post #291021 Thu Mar 03 2011 3:13pm
johnsmall
had simular problem when i went over a bump knock from left hand side took it to my local garage turned out to be a ball joint, had it replaced total cost was £88
john JOHN
2005 RR SPORT BLACK COLOUR CODED 22" WHEELS CREAM LEATHER
Post #291033 Thu Mar 03 2011 5:00pm
ENVOY
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Arctic Frost
all My sports have suffered from rattles, LR did try and sort it on the new ones but they was never successful but had my D3 done last year and that was AR drop links and new lower arms, The LR specialist always maintain that there is nothing wrong with the drop links but the vehicle needs to have the weight removed from the wheels and the suspension hanging to find that they are knackered.
Just bought a 53k mile RR sport with the same knock, it will go in next week to be sorted! some of my Previous cars
P38 Range Rover Autobiography
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
RRS 3.0 HSE BALTI BLUE
current vehicles
RRS 3.0 L494 Autobiography
Audi R8 V10 Spyder
AC Cobra
Landrover Defender 90
Landrover Defender 110
Suzuki Jimney
Post #291238 Sun Mar 06 2011 9:02am
drdelrrs
Before going over the top you might want to check itsnot somehing simple like the bonnet release cable that has come unclipped.These can rattle as can many other similar bits.
Suspension compnents will normally emit more of a thud or knock in response to a bump or pothole.
Ball joints can usually be detected by rocking the steering wheel quite violently left and right (with car stopped, of course) and, if you can manage it, without the engine running so no power steering. If a ball joints gone or the rack's bushes are weak you'll hear them or, with a mate watching under the car you might even see the ballend moving.
Post #291405 Mon Mar 07 2011 7:04pm
