![]() | Home > General > RRS and rough Driving ! |
My view is that the car can handle it - the only problem is that the wheels & tyres aren't always up to the job. 2005 Zambezi TDV6 - Gone but not forgotten
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Driving any car rough in any conditions is not going to be good for it |
SemiticPride Member Since: 23 Aug 2010 Location: middle east Posts: 13 ![]() ![]() |
well one of the reasons I'm asking the question is coz where I live, a lot of roads are kinda messed up!! I went through a road once that was so filled with rocks where I literally waited for the car to just collapse into pieces. I'm used to land cruisers or nissan patrol in this kind of environment but maybe the RRS shouldn't be used this way. |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
I suggest you have a look around here or have a look on you tube to see what it can really do, it is very capable of handling rough terrain |
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 ![]() ![]() ![]() |
Hello from UAE to Saudi!
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
Range Rover Sport Rear Wheel Carrier from Australia (its towards the bottom of the price list): http://4x4intelligence.com.au/4x4i%20products%203Mar2010.pdf |
I'd like to see how they've addressed the centrally located number plate. The LR3 rear door design made it easy by off-setting the number plate to one side.
The number plate is attached to the wheel holder. There will likely be photos of a car with this fitted in te next couple of days from a meet over this last weekend. |
Thanks for the info...please be sure to post a link if you come across the pictures!
The winch can be fitted to a RRS, but it prevents Active Cruise Control working if you have it fitted.. Not the Air Conditioning as far as I understand .
Ah...thx for clarifying that. May be it's the RRS SC that can not fit the winch to then? Or...is it possible to fit a winch to all RRS models without compromising other factory fitted equipment?
As I understand the intercooler airvent on the S/C is lower than on the other engines. Thus when fitting the underbody guard you need to modify it like some of the guys in the US have.
lord Fenham Member Since: 05 Mar 2010 Location: tynemouth, newcastle uk Posts: 53 ![]() ![]() |
Hi all,
