Home > General > Help - spare key dropped below rear seat! |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
The whole rear seat comes up and forwards (for loading the boot up)
Tue Feb 08 2011 10:39am |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 |
Slide your hand down the back of the seat and rub left/right.....you will feel a little loop of leather and tug it to lift the seat base forwards.
Tue Feb 08 2011 10:42am |
kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382 |
Tue Feb 08 2011 11:06am |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 397 |
Its in the back corner, you should see it when you open the doors. Don't look towards the centre, its at the very outer edge. |
Tue Feb 08 2011 12:58pm |
My tabs are located centrally to each outer seat (one on each side). They've probably just been pushed down between the leather iso-fix cover and the seat base. RRS gone
Tue Feb 08 2011 1:16pm |
Must have changed then, mine are outer edge of each seat. 2005 RRS S/C |
Tue Feb 08 2011 1:19pm |
Must have
Tue Feb 08 2011 1:22pm |
Wed Feb 09 2011 9:45am |
hmmmm sounds like something's jammed.
Wed Feb 09 2011 9:52am |
Have you tried the other side?
Wed Feb 09 2011 9:59am |
You have to pull upward, the seat pads are hinged at the front so the rear has to come up and arcs toward the front seat.
Wed Feb 09 2011 10:18am |
Wed Feb 09 2011 11:25am |
A12DY B Member Since: 21 May 2008 Location: WEST MIDS Posts: 335 |
there is a release mechanism,
Wed Feb 09 2011 11:35am |
2007 RRS so tab may be to side of seat as per Carlos's post
Wed Feb 09 2011 11:51am |
