Home > Technical > RRS TDV8 Electrical Problem
englishempire
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Hi all, i have a 2007 RR Sport TDV8 with 65k miles and fsh which i have a fault with and hope someone can help me in identifying the problem. I was driving the other day on the motorway and it started to hesitate very slightly, this got gradually worse until it started lurching heavily under any sort of acceleration. This eventually ended up in a dramatic loss of performance and the car would only go quite slowly with hardly any power at all. I norticed then that all the relays under both sides of the dash started to click away furiously with multiple electrical failiures in the car, like windows, heated seats, blower etc all not working but intermittently so the car would burst into life again albeit briefly. I stopped the car and left it overnight. The next day the car started and the engine check light was on for a while but the electrics functioned ok. I had it taken to the main agent where it is now but when i was there with the car and started to show the technician, there were more faults showing on the dash like gearbox fault, engine fault and suspension fault. The diagnositic showed up two pages of failiures but i think this is obviously something like an earth somewhere or some other electrical control unit. Does anyione have any experience of this kind of problem with a TDV8? Any suggestions will be greatly appreciated, the dealer has not yet found anything to report. V8
Post #287910 Thu Feb 03 2011 9:27pm
Melbop
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Hi
Tell them to have a look at one or both of the turbo air intake pipes.
A friend of mine had exactly the same problem whilst on the M62. Not so many electrical faults though.
His tdv8 was transported to a stealer that took four days to figure it out.
The inner lining of the pipe had un wrapped itself and starved the engine.
Post #288016 Fri Feb 04 2011 10:52pm
Tboner
i would agree possible loose intercooler pipe had it do the same thing on My09 car 2014 5.0SC AB
Gone 5.0 SC
Post #288024 Sat Feb 05 2011 12:18am
