![]() | Home > Maintenance & Modifications > Where can I find 12v on ignition behind radio? |
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Radio should have both a permanent live and a switchable live I believe! |
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
It is probably easier to take the 12v from the green wire that goes to the cig lighter '08 RRS TDV8
Aramis_1970 Member Since: 30 Jan 2011 Location: Lecco Posts: 1 ![]() ![]() |
Is the green wire you mentioned accessible from behind the radio or not? Really nothing in that area?
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 ![]() ![]() ![]() |
Use a multimeter to find 12v wires MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports |
Geert Member Since: 12 Dec 2010 Location: Belgium Posts: 13 ![]() |
It is not easy to use a multimeter. I have tried everything on the cables to the radio. The inlets of the cable are very thin so you need to use a small paperclip or something. A bad connection is easily made.
You can maybe use a drawing pin through the wires to find a good 12v
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
As you say, there's no ignition 12V supply at the head unit.
