Home > Maintenance & Modifications > Test of Tracking
Steuart64
Scotland 2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Test of Tracking
After having 2 tyres blow out at once in a pothole Id thought I would get the tracking checked. Local Dealer wnats in excess of £300 just to check Big Cry
Stated it takes over 3 hours and uses lasers.
Are we really using technology of that expense for a mechanical check on a vehicle designed for off road?
Is there a reasonable alternative check that wont invalidate warranty? Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill
Ex - Audi A4 Cab 3.0TDi Quattro
Ex - Freelander2 SE TD4
Ex - CRV Auto
Post #286379 Wed Jan 19 2011 5:26pm
BIG DJ
I would have thought any tyre shop that does four wheel alignment would be ok.
Post #286385 Wed Jan 19 2011 6:17pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Re: Test of Tracking
Go here and enter your postcode http://alignmycar.co.uk/ the last time i had it done it was £50
Post #286392 Wed Jan 19 2011 7:04pm
yogibear
United Kingdom 2007 Range Rover Sport TDV6 SE Java Black
as chris
i have used these guys and can highly recommend them..
think i paid around £45 for check and then up to 2 hours labour dependant on the amount of work up to a max of £200.
Both checks i have had have been under £80 and makes a noticeable difference.
you get a print out of before and after so you can see what has happened. Thumbs Up
Post #286405 Wed Jan 19 2011 10:30pm
