nigelpugh
Guys,
Hope you dont mind me also posting this here, but its essential about the same system so would welcome any feedback too.
Thanks, Nige.
Hi Guys, sorry for not posting for some time, work pressures and all that.
I have some info and questions again re the B/T and Factory PTI.
First a quick back-grounder for those that don't know me.
I took delivery of my new D3 TDV6 HSE back in November of 2004.
As it was one of the very first UK cars, I was told I could not have the factory fit PTI, and would need to wait until the B/T retrofit came along.
By the time I was really fed up with using headsets, I finally ordered the two options that make up the b/t retro fit kit.
I should say at this point that my dealer told me when I ordered it that it would include a charging cradle, to the effect that they even had me buy a new mobile, a Nokia 6230, as it was one of the few that were supported.
The install was carried out which took over two days, when I did collect the vehicle there was no cradle, my dealership told them that LR had misinformed them.
I did get the new buttons on the steering wheel for answer, end and voice activation.
However the whole setup was very bad, with poor call quality, no support for call waiting(it just hangs up the first call), the voice instructions from sat nav, speak over the top of the voice from the telephone call, if you have the TP traffic info on the radio this just cuts off the call when interrupting etc.
But the real problem is that because there is no external aerial, and you end up putting the phone in the drinks tray, calls are dropped almost every call as the strength fails on the phone signal, as the d3 seems to be a great faraday cage.
Now I should also say at this point I had spoken to LR technical about this, who have told me that there will be a new version of s/w for the b/t option I have that will fix some problems, but my local LR dealer knows nothing of this.
I also asked them about actually retro fitting the proper pti kit, but they said it was not possible as my vehicle had a glass roof.
I then forgot about it for a while, but recently had so many calls drop due to bad signal strength that I decided to look into it further.
So before I continue on this track I have some questions.
Can I have a response from the d3 owners on this web site who have:
A: a retro fit bluetooth kit
B: the original factory PTI.
Feedback on your thoughts on both is required.
Then if you guys are all interested, I shall begin with the rest of this book at bedtime story.
Hoping for lots of response!!
Nige.
