![]() | Home > Technical > Disable Headlight Washers? |
alanad Member Since: 01 Dec 2010 Location: Livingston Posts: 133 ![]() ![]() ![]() |
Switch your lights off if you are using the washers - be careful if it's dark mind. |
Rislar Member Since: 04 Oct 2010 Location: Western Lake District Posts: 194 ![]() ![]() |
Yep i agree, headlight off works! |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Won't your car get dirty just driving it in this weather and with all the salt on the road |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
Dirty??? You must mean it is becoming more and more cool dirty! Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Probably easiest way would be pop the washers off and disconnect them? I may be wrong tho. |
Adam RRS Member Since: 19 Nov 2008 Location: St. Albans, Hertfordshire Posts: 567 ![]() ![]() |
Ahhh cheers guys, it works!
No need to wash the lights unless there switched on |
