Home > General > switching on sat nav
gingerbiker
been to look at a car with touch screen/bluetooth; the unit looks exactly like the sat nav unit in another car i have viewewd
is it possible to have the sat nav enabled, or is it simply not present unless installed when the car is built?
carl
Post #282122 Mon Dec 06 2010 6:16pm
Jimmy_75000
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
If it has the built in touch screen, it has the satnav.... Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #282192 Tue Dec 07 2010 7:37am
gingerbiker
Went to see the car again tonight. The screen shows radio cd/ 4x4 info but definitely no sat nav option. Does your post imply it can be enabled?
Post #282247 Tue Dec 07 2010 6:17pm
BIG DJ
What's the details of the car?
Post #282248 Tue Dec 07 2010 6:32pm
MAW
Doesn't stack up - is the disc in maybe?
I don't know how it would behave with no disc - may say no disc...
Post #282261 Tue Dec 07 2010 8:19pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Ginger Biker - where are you based, i am Selby way and if you need any help with a disc to try it out let me know Thumbs Up
Post #282262 Tue Dec 07 2010 8:27pm
gingerbiker
@leedsunited
many thanks for the offer! ill let you know if i buy this car
when i try to select the nav option it says 'navigation unit not fitted'
cf
Post #282436 Wed Dec 08 2010 9:43pm
leedsunited
gingerbiker wrote:
@leedsunited
cf
What spec is the car, SE, HSE Question
Post #282478 Thu Dec 09 2010 8:16am
check under the passenger seat for the sat nav dvd
If it's there then
a: Check for a dvd in it
b: Check the plugs at the rear of the unit, they sometimes come lose
If no dvd reader then
a: It's been removed (if SE or HSE spec)
b: Someone's installed the head unit but not the sat nav reader RRS gone
Post #282517 Thu Dec 09 2010 1:33pm
matrix13
check with manufactor via reg number it will tell u the spec
Post #311894 Mon Aug 29 2011 9:43pm
