Home > Technical > Another fault
Another fault
Suday afternoon - TANKING up the M6 , just gone past Corley services and up the hill - quite windy & doing approx 90mph in the outside lane when ... Censored ck what the hell was that Shocked Shocked Shocked
Loud noise - heart in throat - Sad
Too my surprise the trim on the drivers side "A" post had come off and was hanging on [ just ] at the bottom where it dissapears below bonnett level.
I couldn't stop so I lowered the window fractionaly & continued on holding it in place to prevent any damage or loss. I eventually left the motorway with frozen hand and pulled over to check what had happened Rolling Eyes .... it had simply popped off Shocked although it would appear that the trim is missing one of its fixings at the lower end , so having thumped it back on / into its housings I will be off to the dealer later today to get it replaced Evil or Very Mad
Has anyone else had this happen ?
Post #22264 Mon Apr 03 2006 11:15am
Bad luck, MDP, I bet you needed a medicinal brandy to warm the hand up after that! Wink
Post #22267 Mon Apr 03 2006 11:25am
kam100
Sorry to hear that MDP.. glad you didn't loose it all together and were able to hold on for dear life! any damage apart from it coming off?
Hopefully not a big job, but worrying that bits are coming apart when you're tanking it..
Post #22271 Mon Apr 03 2006 12:11pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
There is a Technical bulletin about water ingress due to the A pillar trim coming loose
It is called
No.LS501-006
16 August 2005
Water Ingress via A-Pillar Exterior Trim or A-Pillar Trim Adrift
A customer may report a concern of the illumination of miscellaneous warning lamps and/or water in footwell.
Cause : Water ingress through the lower slot in the body A-pillar, where the A-pillar exterior trim lower location peg locates.
Action : Should a customer express concern regarding the above, refer to the Service Procedure detailed in this bulletin.
Basically there is a small plastic peg that is part of the A pillar trim that inserts itself into the A pillar, the fix seems to be to remove this peg and seal the hole with a patch and then replace all the clips etc and the trim. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #22272 Mon Apr 03 2006 12:15pm
nickp
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Yep mine is in with the dealer this week for a soaking wet front passenger footwell . Looks like this could be the cause !!
Post #22302 Mon Apr 03 2006 1:20pm
Or potentially a loose HVAC hose that pi**es water into your footwell from behind the centre console... this has been reported here on a couple of occasions Very Happy
Post #22303 Mon Apr 03 2006 1:27pm
Thanks Adam,
It would appear [ looking back at the incident ] that this fix has already been done on mine then - because I inspected the trim closely before refitting it & spotted that the lowest of all the fixings was in fact missing!
It has been reported to the dealer and they will look at this when it goes in for repair again on 10/4
1. Sort why still getting "bong" for suspension fault etc etc
2. Investigate/cure why I am getting a vibration/knock through steering column
3. Solve the mystery "A" post trim affair
4. Investigate & solve the annoying rattle from somewhere behind me "B" post or rear door or..???
Post #22304 Mon Apr 03 2006 1:29pm
nickp
I also had the steering/vibration knock and my dealer replaced some lower part of the steering assembly , which has fixed it .
Post #22310 Mon Apr 03 2006 1:52pm
Cheers nick Very Happy
Post #22320 Mon Apr 03 2006 2:49pm
RRUK
And mine is in next week for new wiper blades, steering shaft, tailgate struts and an oxygen sensor.
It's all fun and games hey? Razz L319 D4 HSE
1982 Series 3 SWB
Post #22340 Mon Apr 03 2006 3:40pm
It made me laugh though - blasting up the M6 on Sunday thinking I just love this car .......... then whollop.... trim pops off Evil or Very Mad still love the car though Wink just hate the build quality Evil or Very Mad - no offence TB Embarassed
Post #22343 Mon Apr 03 2006 3:49pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
None taken. Thumbs Up Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #22363 Mon Apr 03 2006 10:01pm
Some to add to the list:
6CD player stuck on Saturday between disc 1 (Val Doonican) and disc 2(Barry Manilows greatest hits)
My favourite of the 2 is Barry Manilow by a nose.
Also, rear passenger side seatbelt is really noisy.
CD player miraculously started working again on the way to Gaydon on Sunday!?! Runner up - 2009 Best Avatar Award Sad
Post #22398 Tue Apr 04 2006 9:09am
My god! I think you've just taken the crown of dubious music taste from RRUK and his labelled CDs! Wink
Post #22413 Tue Apr 04 2006 12:30pm
I lied about disc 2, just out of embarrassment Embarassed though "The Man" was cooler!
It was actually "Roy Castle plays Easy Listening Jazz, Vol 3"....NICE! Embarassed
You don't want to know discs 3-6! Runner up - 2009 Best Avatar Award Sad
Post #22427 Tue Apr 04 2006 1:45pm
